When in the guide and I click on an over-the-air channel, and then Watch Live, it goes back to the guide. I’ve rescanned and have 88 channels available. I’ve always been in range of the local channels and have an HD antenna attached. I’ve tried turning the antenna amplifier off. I’ve tried restarting the Tablo device. I’ve rebooted my 3820RW Roku device.
Hi @winkld ,
As per Ron’s post, are you using a Roku with OS 14? If so, it’s a known issue we’re working on. The post Ron1 tagged explains the problem, a work around and what we’re doing about it.
We are a Roku household with 5 working units. When I couldn’t get the Tablo to play OTA channels I thought it was my dated Roku unit on our main TV and ordered another one.
Well that was bad money spent as I soon found out the newer Roku is incompatible with Tablo delivery of Over the air channels. This is why I bought Tablo and now have to wait until there is some Tablo updates for compatibility?
New User disappointment.
Guess we all have to wait for the fix.
We’re sorry you’re running into that.
A Roku update just dropped: Tablo Roku App (4th Gen) Update (v. 0.8.900) - Announcements - TabloTV Community . It should help.
@James_Kuenzi - if you highlight the (Gen4) Tablo tile in your Roku, then press the asterisk (*), it’ll show you the version and build number of the Tablo app. The new one should show Version 0.8 build 900.
