Tried setting up a Tablo for the first time today.
You need to connect directly to the Tablo when you first set it up
I don’t follow. I need to connect what directly to the Tablo?
Also, if I unplug the ethernet from the tablo I don’t see any Tablo networks on my phone or computer.
Ok it found it via wifi. Still not working when connected via ethernet
Oh sorry, didn’t see you have it connected directly
Try this.
NP, thanks for the replies
I assume you mean the Ethernet cable is running from your router to the Tablo and the coaxial cable is running from your antenna to the Tablo?
Yes, that’s correct to all
It is working via wifi now. Not sure why it won’t work via ethernet
@dherrick21 there is something you have to do to change from wifi to hard wired… Might search the forum for that or maybe someone will reply. I don’t recall what it is.
@Jestup, there is nothing you have to do to go from wifi to hard wired except plug it into the ethernet port.
@dherrick21 there is something you have to do to change from wifi to hard wired.... Might search the forum for that or maybe someone will reply. I don't recall what it is.
To change from ethernet to wifi, just quick press/release the blue reset button to reboot the Tablo. Nothing needed for wifi->ethernet (as @snowcat says).
Yes and it is recommended you run the Tablo hard wired to ensure adequate speed for streaming. Your front end devices such as Roku can be wireless.
@theuser86 I have 2 Tablos wireless and one Roku Wired and one Wireless and I have no issues
What is the make and model of your router? I make a bet it’s not your average Joe’s router
Apple Airport Extreme, latest version. And I have a couple Airport Expresses to cover my downstairs. But the Tablos are about 20 feet away.
