@thebellenir Well, thank you very much! We really appreciate the feedback, and all of the kind words
To all… it’s not “the problems” that matter, it’s the response… and @TabloSupport responds (just maybe not as fast as some would like!). Good job!
Any updates on when chromecast will work with Android. Kinda a HUGE feature thats lacking especially since there isnt any HDMI out on the unit.
Sorry to hear about your Chromecast/Android issues, Kovs. I use the same setup, and it seems to work fine. I am even using a Nexus 7, as well.
However, I am running 4.4.4 still, and that is why I am probably still in business.
Nevermind.
How come nobody seems to remember Android 3.0, 4.0, etc…? Google is not great at .0 releases.
How come nobody seems to remember Android 3.0, 4.0, etc...? Google is not great at .0 releases.
sad but you are correct
It’s that way for almost any software product. IOS 8.0, Windows 8.0, etc.
This is a minor nitpick but I seem to get inconsistent fast forward results. Sometimes it’ll advance a few seconds, other times it’ll be more (15-45 seconds?). Also, it seems once we get near the end of a show the fast forward buttons don’t respond. If I pause the recording being watched, it’ll ff fine.
Well, @TabloSupport and @TabloTV, it worked fine until yesterday. Unfortunately, the web-app will no longer connect
I’ve cleared my cache, updated my OS, deleted and re-added the app…reset the Tablo, everything I can think of but it won’t connect.
Well, @TabloSupport and @TabloTV, it worked fine until yesterday. Unfortunately, the web-app will no longer connect :-( I've cleared my cache, updated my OS, deleted and re-added the app...reset the Tablo, everything I can think of but it won't connect.
Are you able to connect to your Tablo with any other devices or is it just limited to the web app on a single device?
@tablotv So with the new 4.1 compatibility, does that mean there will be a web app for Kindle Fire HD’s?
@jbanks25 - We do have an app for Kindle Fire tablets: https://www.tablotv.com/tablo-products/#tablo-apps
The Android tablet app is designed to work on 7" screens but I hear it works on the Kindles that are smaller.
The web app should work Kindles too. Give both a try.
When I tried in the past they showed up as unavailable on my devices because they were older and based on 4.1. I guess I will ahve to head back to the store now and send them to my devices.
@tablotv Whoops, I was wrong. Mine are based on 4.0 still, so I’m not compatible.
Sorry! We struggle to get things working on 4.1 so 4.0 would be a BIG stretch.
It’s OK, there is always plex, Silk will also play video it if you copy and paste the link it gives you when the web browser fails initially… There are always work-arounds. Lucky to not be a typical consumer
I feel the pain of @TabloTV. Trying to support older technology is hard and at some point you have to cut it off. Regardless of the loss. As an example, iPad 1 is pretty much out of luck with iOS updates. It would be nice if Tablo could support every device in the world and every OS, but at some point there has to be a ROI for that work. Personally I would prefer they work on the current requests for currently supported devices and when all of that works then “maybe” look back.
@Jestep - The foundation of the work we’re doing for the new Roku channel is the core of what we intend to use for the API. It’s coming along nicely but I don’t have an ETA to share on when we’d launch a full-blown developer program.
