Seems the latest update may have some issues. All of my attempts to load live or recorded video through the web app results in a blip of audio and then freezes on a single frame while loading indefinitely. Running Safari on Mac OS X 10.11.1.
[quote=“TabloTV, post:1, topic:3988, full:true”]
The new HTML5 player should offer MUCH smoother playback and improved performance, even on lower-end PCs so we hope you enjoy it.[/quote]
The HTML5 player rocks, now I can watch LiveTV on an older PC that was never able to play video smoothly…
The webapp version number is 1.0.23-597
There is definitely an issue with iOS 9 Safari (on both iPad Air 2 and iPhone 6s). I can only connect to one of my Tablos—the one that I try first. The second Tablo won’t connect. A connecting message is displayed for < 1s, then it returns to showing the connect screen showing the two Tablos.
This state persists until I clear the website data for my.tablotv.com; at which point, I can successfully connect to,either one (but only the one I attempt first).
Just to be clear, I can repeatedly successfully connect to the Tablo I connected to first after I cleared data. Furthermore, I can never connect to the other unless I clear data and attempt it first.
One might ask, why do I care? Well, for the iPad, the web app is the only way to delete all.
As for the iPhone app, I’m worried you will push the current web version as an iPhone update; and thus, break the iPhone app.
