After sending the support team a message about the issue talked about here, they said that this new version would probably fix it. However after testing it, it isn’t fixed. Should I open a new ticket with the support team?
It will only show up if UPNP doesn’t work. If you already have UPNP enabled, you’ll have to uncheck the Tablo Connect box and hit refresh on your web page.
You said the port information will only show up if UPNP does not work. In my router, I do not have UPNP turned on. But still I am unable to see the port information. What’s wrong?
I did the port mappings manually in the router. Is that why I am unable to see the port information?
