I am having trouble when playing back recordings using the web app. I have used Chrome, but it does this glitch in other browsers, and I have tried the beta web app as well.
What happens is this: When I am watching a show, the Tablo will kick me out and go back to the TV show logo screen (the image you see when you first start the stream of a show), then it will pause, then buffer, then resume where it left off. It’s not just a buffering issue, it seems like the Tablo is having trouble reading from the hard drive.
I have used the Tablo RIpper app to get files from my drive. I tested them on my computer directly. The files were recorded fine. There were no issues with the files; they were not corrupted. This appears to be a playback issue through the Tablo. It appears like it cannot maintain a steady stream consistently.
I am using a 500 GB WD Elements hard drive. I was using the 720P 60 FPS quality. BUT I have recorded at lower qualities, and this playback glitch has happened then as well.
It’s not a router issue. My router can handle the streams fine. I am able to stream from other sources (Netflix, Amazon Prime, etc.) at 1080P and have no problems. Also, there are times when the Tablo does work fine, and my router can obviously handle the 1080P quality fine then. It’s just that intermittently (and this is of course very annoying) the Tablo will just kick me out of the stream and restart.
I have tried all manner of different setups physically at my end. Like using a booster on my antenna, not using the booster, using a splitter, not using a splitter, etc. I have moved the device physically away from the router. Moved the antenna around. Nothing seems to take away this playback issue.
I have also reformatted the hard drive and reinstalled the firmware on the hard drive. I then did a factory reset of the Tablo. Still have the glitch.
Any ideas out there?
