A new maintenance firmware release is available for Tablo which includes some minor but helpful fixes to make your Tablo viewing experience better.
Do you need to upgrade to 2.1.18 before it will prompt you for an update to 2.1.20 ?
I am on 2.1.16 and it is still asking me to upgrade to 2.1.18…
@lowbee You can skip the .18 release - your Tablo just needs to ‘see’ the .20 update. It checks for a new update every few hours. You can speed this up just by rebooting your Tablo. When you get a prompt (after it’s back online) it should be for the .20 update.
I installed 2.1.20, deselected the “fast live TV startup”…and no buffering instances thus far. Looking good. Thanks!
I just applied the .20 release remotely (because I can), and I think it has changed the way Live TV is being displayed through the Android web app.
I’m not seeing an update?
never mind the button just started working
Are there any plans in the future for parental controls or children access, where it will only display specific rated shows and not allow access to delete shows. This way when I connect this to my daughter’s Roku I wouldn’t have to worry about them deleting shows or viewing inappropriate content. Also, are there any plans for the roku apps live TV to be displayed like it is on the android app?
The closed captions on my Roku (2 XS) are blinking. There seems to be something wrong with the duration of each caption (i.e. not long enough). The problem seems more pronounced on live-news type shows.
wow i can’t watch it on my cell phone without constant buffering? what happened with this update? i was able to watch last night but after the update it is terrible. i tried a recording too and it’s as bad as live tv. help
After this update I am getting a message that: Your hard drive “TOSHIBA External USB 3.0 0 (2000 GB)” needs to be formatted before it can be used for recordings. This will erase all of its contents. Is this expected?
@Kib, I have both the 2-tuner and 4-tuner models and the update went smoothly. I tested existing recordings, etc., and did not have any issues. I did not need to reformat either hard drives.
I hope that it will help to get my Roku 2 to run.
Very smooth update for me…
Things are looking good in the Man Cave Cinema.
2 Tuner Tablo
2T Seagate Backup Plus
2 Roku 3
1 Android phone
2-tuner tablo wd element 1TB. Using PC chrome browser my.tablotv.com for upgrade. Received installation screen - proceeded to down load, install, reboot. After installation reboot, disk is undetected. After manual reset disk is undetected. You can see that there is no power to the disk. But pulling the plug and re-pulling in the device found the disk. And if you clear the chrome browser cache and restart my.tablotv.com WEB page, you can see a change to the connect screen.
I did a bad thing. I’m at work & hubby is home so I told him to go ahead and do the upgrade. It got stuck at 21% for a long time so I told him to power Tablo down so it could start again. It came up fine but not asking to do the upgrade. Settings screen now shows ver 2.1.20. How do I tell for sure?
not seeing
where should it be?
