Maybe my review can help someone save their the me and money on this piece of crap device.
Don’t waste your time or money on this device. While the concept is interesting, the product simply does not work.
So far this mis-adventure has cost me close to one thousand dollars and I am further behind then when I started.
I have had to buy new hard drives because the support people insisted the drive was the problem (of course all of the drives work perfectly plugged into my computer and router).
Then I’m told it can’t handle the resolution (an option in their app) I selected. I have it at the lowest setting which means when I can get a signal it looks like crap.
The remote access has never worked, when I asked for help getting it to work, I get brushed off and told they will address that once they get the device working - of course since the device has never worked properly, they never bothered to address that issue.
With today’s firmware update, the time on the device is now 6 hours and 35 minutes ahead. The schedule won’t download either.
The funny thing is, if I connect the high end antenna I bought for this device directly to different tv’s, all the channels come in crystal clear. When I point that out, they come up with some excuse about the quality of their tuners. My thought is, then fix your poor quality tuners!
I’m 10 months in at this point with a piece of crap device that if I am lucky I get 2-3 channels somewhat working without constantly resetting the box or constantly reloading the first 3-4 minutes of the show I am trying to watch.
They have refused to replace the unit claiming I must be doing something wrong.
Just stay away from this device. Check out their forums (if you can get their site to even load) to see all the other customers that are having issues.
Save your time, money and frustration. Get an antenna and just watch live TV instead and save yourself hundreds of dollars.
