For no reason that I can tell I am now having issues with recorded shows. No issue with live that I can tell.
Suggestions?
@napercort Yikes - what kind of drive are you using? Send me the details in a ticket and we’ll take care of you.
It’s probably a coincidence, but I had a “Loading” issue watching live TV this morning over Roku. I backed out of the channel and went back in again, and it started re-playing a short segment right up until the point where I got the Loading screen on the Roku. I “fixed” it by hopping through other channels so that all the tuners got used and then going back to the original channel.
Ticket submitted, @TabloSupport
@Pundit Thanks!
I have had this issue as well and there is another thread in the Roku forums found here (http://community.tablotv.com/discussion/480/playback-buffering-on-recorded-events-very-frequently#latest) that talks about this sort of thing too. It may be a coincidence or unrelated to the Tablo channel on Roku but worth checking out.
UPDATE: as of this note, since i did the unplug of the tablo and re-setup the power ethernet, I have not (knock on wood) had the loading issue repeate. Perhaps the recycle of power was what was needed?
@napercort Sorry - I didn’t get a notification (and apparently missed) your last response.
@TabloSupport Will do and no worries, you guys are busy putting together a great product and keeping it that way!
I feel like such a muppet…my “Loading…please wait” issues are once again due to signal issues. For some reason my local ABC affiliate has gone from 5 green dots to 3 amber dots, and sometimes it drops out of the channel scan list entirely. Le sigh.
@Pundit, I have seen this same thing happen to me, in my case it was FOX on channel 11, which I know has great signal. It went from original 5 green dots to 3 as well. And if I do a channel scan it won’t show up, but even on my TV that has terrible reception gets it just fine. So I would agree with allowing some type of tuning that is not included in the channel list. I just wonder how hard of a feature this would be and if it is something that may never come
So, because I was talking about it I decided to do a re-scan:
@Jestep It is a bug - just had a chat with our engineers on this. They’re aware, and are working away!
@TabloSupport thanks!
I just hooked up my 4 tuner last night. I have 2 tvs hooked up, both roku3s, and both wired. one is direct wired, one is using powerline adapters. the one with the powerline adapter was showing the “loading, please wait” pretty often. I changed that one to wireless and it seemed to fix it. I don’t understand why the one with powerline adapter was having problems. I’ve been streaming using the powerline adapters fine for about 2 months. the adapters are tp-link 500mb. the wifi seems to be working fine, but would rather use the powerline Ethernet. should I try to reset the tablo? thanks
@brg88tx Power line adaptors don’t solve everything - depending on the wiring in your house, their effects can be limited.
I have the problem loading, please wait and it happen on local channel.
Lately (seems since the last update) I have been getting the Loading… on just about every recording. I had a powerline that died so I connected via WiFi. Since then I have the powerline set back up. Still getting the Loading… screen.
If a bug, please fix. I am so tired of seeing it. Very frustrated.
On a related topic…how do I know that I am via Ethernet now? As I stated, I was using WiFi but have since set up my Powerline for Ethernet service, but I don’t know how to tell if it is still WiFi. Does it automatically switch?
When you plug in via the ethernet jack it is no longer using wifi
