I can actually watch live TV with relatively no LPW messages on the second to lowest Max Recording Quality setting, HD 720- 3 Mbps.
I would still like to watch in higher 1080 quality on the channels that I receive that are 1080, but even at MRQ of HD 720- 5 Mbps (recommended) the LPW frequency is much higher…
Are you running the Tablo and Roku on the 2.4 GHz band or 5 GHz band?
This is likely due to poor WiFi signal resulting in slow WiFi speeds. I suggest you hard wire at least the Tablo to the router. Engaging in “Double WiFi” creates a lot of latency problems - that is Tablo to router via WiFi and then router to Roku via WiFi.
Do you have another WiFi playback device you can test on? iPad? Fire TV? Nexus Player? Laptop?
2.4 GHz or 5 Ghz wireless? If 2.4 are you using the microwave? What router / wireless access port do you have? My Tablo, and all my devices are on 5 GHz wireless and using the 720 prefered. No issues. The higher the resolution you record at, the larger the files will be. Most of the stations are 720 and for the few that are 1080 I watch live with antenna on tv. Would be nice if quality could be set per channel, then would record the way the station is.
@cmb9er Coming from someone who spent close to $200 buying Powerline adapters for the whole house, then ended up selling all of them and upgrading my router to the Archer C7 linked above by @theuser86, I would personally recommend upgrading your router instead, considering you will get massive increases in speeds for all devices, and it is proven to decrease LPW for all devices using Tablo. When I had Powerline (AV2) adapters, it would work very well sometimes, but it would need to be unplugged or reset relatively too often. Right now, the Roku is having issues with handling Ethernet speeds, which is how Powerline works.
It’s up to you, but I sure wish I would have upgraded my router before experimenting with Powerline first.
I have used ZyXEL powerline adapters for many years without any issues. I upgraded to the AV1200 about six months ago and use it to stream HD media everyday. No problem at all so far. Highly recommend it.
I ordered the D-Link PowerLine AV2 1000 Gigabit Network Extender Kit (DHP-601AV) before I saw these responses…I will test them out along with the new router first.
If no luck then I will try the suggested ZyXEL units.
I think they will solve your problems, you should definitely have no issues with 720p 5 Mbps quality.
The Roku has a bug for some individuals with the 1080p setting, but that is being fixed now. So if it’s just a networking issue for you, the 1080p setting will work for you too.
