Firmware 2.2.20 on Roku 3900x, 8.1 build 4.90.
My Ultra is running 4113-46 now so you may be on to something with the last two digits indicating specific model.
I just tested both the beta and non-beta Tablo apps and confirmed I still don’t encounter the issue.
The last 2 digits of the Roku OS build, do indeed indicate the Roku hardware model:
17 = Roku 4
04 = Roku 2 (2015)
Since a month or two, I’m not able to go back on live TV. When I try to go back, I just return to live TV at the real time. If I use “pause”, I’m able to see TV program at the right time until I try to skip the next commercial. At that time, when I try to go fast forward at the commecial, the program return at the actual time and I loose what was recorded. It was working well a month or two ago. What happens?
If you’re using a Roku with OS v8.0.1. build 4090 is the problem:
Tablo 2.5.1 app update seems to have fixed the live TV rewind problem on the Roku!
Hi folks - We’ve released an update to our Roku Channel (2.5.1) which should provide a workaround for the issue encountered by some Roku users (with firmware 8.1 Build 4090) that prevented scrubbing from working properly on some playlists, including Live TV.
The update worked for me. Was able to pause and rewind live TV without any further issues.
Thank you very much!
