Help me Obi-Won, you’re my only hope!
I’m already engaged with Tablo Support. They replied to my 14 Jan report of problems (submitted via their support page: https://support.tablotv.com/hc/en-us). I finally received email from them on the 20th of Jan, 2024. So far the support has been a mix of requests that aren’t applicable to my problem (I already provided them with all the information they requested), and a request to run a diagnostic using the ‘RouteThis Helps’ App (which I did). Despite the fact that I’m engaged in support through the support team, I thought I would post here, to see if the community has an information or advice that might help.
I’ve been troubleshooting (since 14 Jan, 2024) a problem with my Tablo Dual 64GB OTA DVR - with WiFi (was this later rebranded as the Tablo Dual LITE (purchased Apr 7, 2018)). It’s been working great for many years. I use the Tablo with my AppleTV set top boxes and the ‘Legacy’ apps available for iOS/iPadOS and AppleTV (tvOS). I also have an external storage drive (a Hitachi G-Drive Thunderbolt 0G03050 4TB USB 3.0) attached to the Tablo. I’m using a 30" Moho leaf antenna in the attic for OTA reception, and have been getting reliable reception (in my area (Aurora, CO)) of 37+ channels.
As I indicated above the Tablo (with Hard drive attached) has been working great; a few problems with connectivity now and then (less than a dozen times since purchase) over the past 5+ years. On the morning of 13 Jan, 2024, my wife turned on the TV and fired up the Tablo app - Legacy Tablo v2.4.1 (last updated 4 mo’s ago? / AppleTV automatically updates apps) on the AppleTV (Model A2843(128gb)/Apple TV 4K HDR, tvOS/Software 17.2 (21K365)).
She was presented with the error message: “Unable to locate your Tablo - Please ensure your Tablo and this device are online”. With the options of ‘Try Again’ and ‘Switch Tablos’. She tried the ‘Try Again’ option multiple times, but that didn’t work. She tried power-cycling the Tablo, but that didn’t help either. Later in the day, she notified me about the problem and I attempted numerous different troubleshooting efforts.
I tried the same steps she tried. I also tried the ‘reset’ or ‘interupt’ button on the back of the device. I tried power-cycling with the external storage connected, and not connected. I tried restarting (soft restart and power-cycle) my router. I tried ‘deleting’ the app from the AppleTV (not just offloading data). After reinstalling the app on the AppleTV, it now wants to try and connect to a Tablo device via WiFi or Ethernet. Neither option works (a Tablo generated WiFi network isn’t visible/being broadcast (I’ve tried this WiFi option multiple times, but a Tablo network never appears. I see lots of local WiFi options available (some are mine, and many neighbors), but there’s never any indication of a Tablo generated network)), and the software doesn’t see the Tablo device on my network (via Ethernet)). It just keeps reporting that it can’t locate my Tablo. I am experiencing the same problems (controlling/accessing the Table) via my iPhone, iPad and the browser on my iMac.
Notably, nothing I do will make the Tablo device’s blue light stop blinking. It either blinks ~4xSec (with reset switch), or ~1xSec with power-cycle (remove power cord, wait ~10+Sec and reinsert). When I attempt the power cycle, I notice the Tablo go through initial software restart with rapid flashing of the blue light (~4xSec), the device communicates with the external hard drive (it has a flashing white light on the front of the device), and then (after less than a minute) the blue light on the Tablo changes to a constant once a second blinking condition. It never stays on continuously. I’ve tried rebooting/powercycling more than 20 times.
According to a network scan (using iNet network scanner for macOS) and my router’s administrative interface, the device is connected to the same network as my AppleTV (with a static/DHCP assigned IP) and the following ports are open: 23/telnet, 80/http, 443/https. I do not have a VPN running on my home network, am not blocking any IP traffic from that device (it is allowed to access the internet via the router) but I am running a PiHole on a RaspberryPI and use a locally hosted Unbound/Recursive DNS server. I am able to ping the device from my iMac’s terminal. Ping statistics (run from terminal app/command line on my iMac) show no packet loss. I’ve turned off my macOS Firewall, a content filter (by ObjectiveSee) and my Pi-Hole during troubleshooting to make sure that none of them are interfering with connectivity.
(Ping results, some redaction/obfuscation)
username@computername ~ % ping 192.168.xxx.xxx
PING 192.168.xxx.xxx (192.168.xxx.xxx): 56 data bytes
64 bytes from 192.168.xxx.xxx: icmp_seq=0 ttl=64 time=5.553 ms
64 bytes from 192.168.xxx.xxx: icmp_seq=1 ttl=64 time=0.681 ms
64 bytes from 192.168.xxx.xxx: icmp_seq=2 ttl=64 time=20.414 ms
…redacted/shortened for brevity reasons…
64 bytes from 192.168.xxx.xxx: icmp_seq=33 ttl=64 time=0.348 ms
^C
— 192.168.xxx.xxx ping statistics —
34 packets transmitted, 34 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.288/1.571/20.414/3.850 ms
I don’t have telnet on my iMac in order to connect to the open Telnet port 23, but the ‘curl’ command offers some information/connectivity (some redaction/obfuscation included below):
username@computername ~ % curl --telnet-option TTYPE=vt100 telnet://192.168.xxx.xxx:23
The response to the curl command (executed from command line in the terminal app) was an ASCII graphic spelling out Nuvyyo, followed by ‘Welcome to Slipstream’ greeting. Is there anything else I can do/any other commands I can issue from the command line which might provide me with some additional information?
As I mentioned earlier, I had no problems with the Tablo until the morning of 14 Jan, 2024, and all my other internet services (and connected devices on same switch and network) are working fine. The blue light on the Tablo never goes solid, no matter what I do. The only thing I haven’t tried is a Factory Reset. I thought it would be best to contact support before I attempted that, as I’ve never done that before (for the Tablo), and don’t know whether a Factory Reset might be advisable.
I ran the diagnostic, but it didn’t tell me anything. Apparently it gathered some network diagnostic information, but it doesn’t let me know what it gathered or what it sent to the Tablo support team. Does anyone know where I can view/see/find out what info it gathered? I don’t like Apps that do that. I don’t trust them, and I’ve deleted the App since I ran the test/diagnostic.
