Is it safe to put a laptop cooling tray under the Tablo?
Yep, many of us do exactly that.
I’ve seen pics of both tablo and external drive on these.
What safety concerns so you have? If you suspect the fan may damage the tablo, look at different models.
Not worried - just curious as I read here about heating concers
Tech Support can check if you have an actual issue to be concerned about…
We can actually check to see if your Tablo is running within safe operating temperatures, so if you have a concern please touch base with our support team: www.tablotv.com/ask-tablo
https://community.tablotv.com/t/tablo-quad-runs-hot/18719/64
