First, is my list of Roku problems with various apps.
- Roku reboots when fast forwarding.
Netflix
Hulu
Sling TV
(Notice Tablo is not in this list, and there is only one problem.)
Tablo loading performance…
Tablo reloading issue only occurs using Roku Wireless-g on untuned to 720p channel, and occurs 1 to 3 times very quickly only at the beginning. Does not reload on 1080i channel.
Ethernet connected loading recorded program averages 3 seconds, and 4 seconds loading after FF or RW.
Ethernet connected loading live TV averages 18 seconds, and 3 seconds when already tuned to that channel.
Wireless-g connected loading recorded program averages 6 seconds, and 6 - 21 seconds loading after FF or RW.
Wireless-g connected loading live TV averages 20 seconds (1 to 3 split second reloading may occur only at very beginning), and 6 seconds when already tuned to that channel.
Here is my list of ways to make your Tablo and Roku more stable.
This list is purely from my own experience with my own equipment, which is listed at the end.
1.a. Place the Tablo vertically, on its side.
This dissipates heat better than the horizontal position.
Heat kills electronics.
2.a. Replace your Roku enhanced remote, a.k.a. gaming/WiFi remote, with a Roku standard remote.
The enhanced remote’s WiFi Direct feature doesn’t require line of sight from the remote to the Roku, and allows you to play games, like Angry Birds on your Roku, but creates serous problems with the Roku, including remote unpairing, and Roku reboots.
The Roku standard remote uses IR, infrared, which requires line of sight from the remote to the Roku.
Recommend purchasing the Roku standard remote directly from Roku to ensure you’re getting a real one, and not a knock-off.
2.b. After you have your replacement Roku standard remote, remove the batteries from your Roku enhanced remote so that it won’t try to communicate with your Roku anymore.
3.a. On the Roku remote, press the following buttons to get to a secret menu screen to change the Roku’s bitrate from Automatic to 3.5Mbps…
Home (5 times)
Rewind (3 times)
Forward (2 times)
Setting my WiFi connected Roku to 3.5Mbps bitrate fixed my Tablo loading problem.
3.b.Reset your Roku’s bitrate back to 3.5Mbps after every Roku reboot.
The Roku resets its bitrate back to Automatic after every Roku reboot.
4.a. Use the Tablo’s Ethernet port, and the Roku’s Ethernet port, instead of WiFi.
WiFi is more flexible, because hey, no wires, but has to deal with a lot more interference than cabled Ethernet.
Also, the Tablo is more likely to have the loading problem via WiFi.
4.b. Connect the Tablo’s Ethernet cable, and the Roku’s Ethernet cable to the same physical network switch/router.
This makes for the fastest, and most reliable network connection between the two devices.
4.c. Use short Ethernet cables for the Tablo, and Roku.
If your Ethernet cable lays on the ground, and is stepped on, it can break.
5.a. If using the Roku’s WiFi, choose Wireless-g.
Wireless-g goes thru walls, and greater distances than Wireless-n.
Roku is also very unresponsive when using Wireless-n at 70 foot distance thru 3 internal walls, which manisfests itself as severely delayed Roku remote button executions.
Equipment…
Tablo Preview app
v2.0 build 9
Tablo Dual
Model #SPVR2-01-NA
Firmware v2.2.2
Wired network: Gigabit Ethernet Switch
Tablo Settings…
Active Subscription
Auto-Delete Recordings - enabled
Recording Quality - HD 1080p
LED - enabled
Remote Access - enabled
Remote Streaming Quality - 1 Mbps
Don’t Record Duplicates - enabled
Extend Live Recordings - enabled
Enable fast Live TV startup - enabled
Enable Leanback mode (TV interface) beta - disabled
WD Elements 2TB USB 3.0 Portable Hard Drive (WDBU6Y0020BBK-NESN)
Roku 3
Model: 4200R
Firmware 6.2 build 3672
Wired network: Gigabit Ethernet Switch w/Tablo
Roku 2
Model: 4210R
Wireless network: 802.11g (~70 feet from wireless router; 3 internal walls between)
Linksys SE2800 8-Port Gigabit Ethernet Switch
Asus RT-N66U wireless router
Shibby Tomato Firmware v1.28.0000 MIPSR2-112 K26 USB AIO-64K
ISP
Razzolink Fixed Wireless 3Mbps download, 1Mbps upload
~15ms latency
Wireless tower is on a mountain top around 9 miles from my house.
