We are aware of this issue and are working on a fix.
In the meantime, you can hit play on the recording, hit the CC button once (doesn’t matter if you are enabling or disabling CC), exit the player, then go back. It will now be in the other state (on/off).
I’m having this problem, too. I’m using a 3rd gen iPad, Tablo is on the latest firmware. Is there an update to how to disable this function for live TV?
There is a known bug… hit the [CC] icon on the video while its playing to toggle it in the opposite directions (just ignore if its showing on or off state with the icon itself) … then exit out of the playing video then go back in.
Yeah i tried that last night but during MNF i just couldn’t get it the captions to go away. Seems to be working again today so maybe i inadvertently resolved. Thanks very much for the quick reply.
I still have the CC’s too. On everything including recordings. I am using an iPad with IOS 9.1 and your app is 1.2.3. Nothing seems to turn them off. Help!!!
Any update about this? I just launched a viewing session on iPad Mini and the CC was blue (engaged, ‘don’t remember how I left it). Captions were rolling and couldn’t turn them off no matter what I did with the CC button.
So I quit the video and reloaded ignoring the blue CC button and now it’s OFF. Is this the way it’s supposed to work?
Would it help if I shoot a video demonstrating how this behaves?
Today after being so tired of CC I tried turning off CC by way of the Apple TV. That worked perfectly. I think Tablo should rethink how they are handling CC. The apps should turn it off on the Tablo. Then all would be good!!
