Hey folks -
After the Masters aired in June we heard from a handful of Roku users that they had difficulties watching the recording:
Given the British Open is airing this weekend we wanted to give folks a heads-up that subsequent testing revealed a Roku-only limitation that does not appear to be documented.
It seems that the maximum length of recording that most recent Roku devices will play successfully is just over 8 hours. Higher-end models seemed to be able to handle slightly longer recordings than the lower-end ones.
When the Extend Live setting is turned on, these 8 hour recordings turn into 10 hours which is well beyond the powers of even the Roku Ultra.
Since weâre still not sure why this limitation seems to exist, it may take us a while longer to find a good solution.
In the meantime, if youâre planning to record the British Open this weekend or any SUPER long recording, there are two workarounds to consider:
- Option A - Temporarily disable âExtend Liveâ within the settings screen of your Tablo. ( If youâve already scheduled the airing, youâll need to unschedule it, disable the setting, then reschedule it. ) The upside is that you should get automatic commercial skip on the recording. The downside is that you might miss any potential runover, unless you schedule the airing directly after which is swimming in the US and Cash Cab in Canada.
Since we didnât test on MUCH older Roku units, they may have a lower âtime limitâ which is why you may want to considerâŚ
- Option B - Set two 4 hour manual recording blocks. Or a 4 hour + 5 hour recording block to catch any potential runover. The upside is that theyâll play with zero problems on any Roku. The downside is that you wonât have automatic commercial skip.
If you watch on any other device BUT Roku, the playback should be just fine.
If/when we find a better solution for this weâll make sure to let you all know.
