H&I channel doesn't update shows on guide
The H&I Network On my system was temporarily removed a couple of months ago. It has since come back on a different channel but the channel has no information on it other than it’s existence. This makes it impossible to record shows or see what is on, other than live broadcasts.
Does anybody have any suggestions as to what to do? I have updated the guide numerous times and have even contacted the TV station, but they are clueless.
Thanks in advance.
Be prepared for a long wait. Been waiting months for Me TV toons to show up. Read this.
Check tvlistings.zap2it.com for your zip code. If they have the wrong channel number for H&I use their contact page to ask them to fix it. They use Gracenote guide data, the same source Tablo uses.
I see that H&I has a contact page. H&I | Contact Us Enter your zip code and see if the correct channel number shows up in the dropdown list. Ask them to have Gracenote fix the channel number.
Thank you very much Ron for your suggestion. I sent them a message and hopefully that will help. Thank you again!
