Gracenote TV Listings Down?
Today is day number 3 of getting the “Oops! Something went wrong.” message.
Anyone else have the problem?
https://tvlistings.gracenote.com/grid-affiliates.html?aid=lat
Yes, I received that Oops message too. I tried just the root URL https://tvlistings.gracenote.com but it didn’t work either. The only URL that works is https://gracenote.com. I didn’t see on their main page where I could view the TV Listings. Or, they’ve permanently removed this content.
Not good, being down for 3 days.
I thought gracenotes was ending all consumer facing WEB sites. That’s why zap2it died.
Did not know that.
That sucks. I liked being able to look at a guide on my PC.
Just found ShowTimes.Com/TV
It has same guide.
Guess we’ll see how long it lasts.
I use to use titantv. It’s more reliable then gracenotes but supplies the guide to businesses. they use to allow consumers on. But now they want you to create an account and I’m not that desperate..
I’ve been getting the same “Oops” message. Oddly this link works:
Full episodes and TV Listings
I’m thinking something is broken there, and somebody needs to be notified. I half-heartedly looked for a place to advise/complain, but I didn’t readily find a place to do that. Maybe somebody with more interest will do so.
Welcome to the community. It appears that direct user access to their listings has been removed but affiliate access is still intact. Someone mentioned a few days ago that this was a pending possibility.
If you click the Back to home button on the link you provided, it’ll take you to another affiliate page. I entered my own ZIP Code in the URL, but it says no data for that ZIP Code.
TV Listings- Find Local TV Listings and Watch Full Episodes
I do hope this gets fixed. It’s the best tv guide around.
Welcome to the community @cindy1. Check out www.titantv.com to see if it works as a suitable substitute for you.
Welcome @Cindy1,
If TitanTV.Com doesn’t work for you, try ShowTimes.Com/.TV
It appears to be the identical guide, but may go the way of GraceNotes at some point.
Unfortunately, I got an error on that link.
Oh darn. It doesn’t work for me here in Canada.
This one does Canada. https://www.tvpassport.com
Thanks! I’ll give that one a try.
Usings the Showtimes.com/tv link now. Only bad part is that you cannot expand the grid to
3 hours.
In the meantime, you can give a look at my primetime TV guide and other guides in the site.
thank you!!! zap was simple and accurate!!
The guide is great and is identical to ZapTV and then Gracenotes. But how can you scrape the data like we did with Zaptv and Gracenotes. Replacing gracenotes with showtimes in zap2xml.pl file doesn’t work.
