So, now I have purchased a Toshiba <a rel=“nofollow” href=“mailto:Canvio…<a href=” profile="" jwhitesel"="" style=“box-sizing: border-box; background-color: rgb(255, 255, 255); color: rgb(25, 145, 193); text-decoration: none; font-family: ‘Helvetica Neue’, Helvetica, Arial, sans-serif; font-size: 14px; line-height: 20px;”>@jwhitesel…is">Canvio…@jwhitesel…is this what the “C” was for? Got it on Amazon for $65.
These ones are confirmed good too! I’m going to start a thread that’s ‘share your hard drive make/model’ so we can make a more thorough list of ‘good’ options until we’re able to support larger sector sizes.
Tablo seems to working as expected with this new portable USB hard drive.
@jploggie - Glad to hear it!
I saw a comment earlier in this discussion about someone getting red exclamation points next to recordings. Ever since Sunday this week, all my recordings are showing up with a red exclamation point and the recording will not play. I can't find anything on this, what is needed to fix it?
@blotto13 Typically when I have seen this, it’s because of either a weak signal, or your hard drive might not be compatible. You could try to rescan your channels to make sure they are coming in green. Also, have a look at this thread for compatible hard drives
Thanks for the tips. I did a rescan of my channels and nothing shows up. So it’s either the tuner in the Tablo, the amp on my antenna, or a bad coax cable between the two.
@blotto13, I had that happen once where all I saw were my SD channels and no HD channels, and I just had to reset the Tablo (press the button on the back) to get them all again.
@Blotto13 - Definitely sounds like Tablo isn’t getting any signals. Send a note to support@tablotv.com and we’ll give you a hand troubleshooting.
I put together a breakdown of my first impressions… but the forum won’t let me post it. its saying its 16745 characters to long what you recommend Forum Moderator?
@PiX65 thatsalotsa characters. :-)
@PiX65 - I’ve adjusted the character limit on posts. Let me know if it still doesn’t fit!
Add to mine a true Android phone app and ios app. I do dig the fact that you allow mobile devices connecting to the webui to be sorta reformatted, but a true app would be ideal… I am of course not telling you anything you haven’t heard or don’t know
This is my second week and only second day with a Roku that could play the recordings.
If you want to skip the rest of
my review my summary is that Tablo is a very good Beta product. <o:p></o:p>
I gave it 4 starts because it handles my critical needs very well but still has a lot of little things they can do better. The good thing is that they are actively making better. I would definitely buy again.
I searched high and low to find an over the Air DVR. Looked at
Tivo- To high a monthly expense feels like cable.
MythTV- Sorry I’m not technical enough.
SimpleTV- Hit or miss on the reviews. I think they are getting better but then I found Tablo.
I only found 2 reviews on newegg at the time but both loved Tablo. I decided to take the risk and tried Tablo.
Newegg’s delivery was quicker than Amazon where I purchased the disk drive. Tablo was very good about answering questions prior to the buy and are still very good a few weeks later. My only issue with support is no quick start manual included with the Tablo. I purchased a Roku a few weeks later and what a difference as far as initial impression. With Roku no problem it took maybe 10 minutes to get installed. Yes Roku is much simpler of a product but that doesn’t excuse no guide shipped with system. My major problem with install was that I did not initially directly connect the Tablo to my router. If support had not told me the setup could be done wirelessly or they had included the setup diagram I later found on line the setup would have been no problem. Just so you know they do have support help but not after 5PM PST and not on the weekend. They did respond over email but it took hours. Which is one reason I call a beta product. Support time should cover the most likely setup times.
Here is how Tablo does on my list of critical things
Ability to get all my local channels. With the free antenna sent with my Tablo by newegg I was missing 3 channels. I replaced the newegg antenna and was able to get all my local channels. Here is one of the little things that they could fix the 3 new channels did not have any programming information. I thought I needed to somehow click on a get data button or something. I searched high and low and found no information on this. Sometime later the programming data started to show up. A message on screen or information on the website could have been helpful. The clarity of my Tablo is better than my cable.
Able to record- Yes I’ve seen no issues recording. The web app does however let you schedule more than 2 shows at the same time when I only have 2 turners. Here again is a reason for calling it a beta product. The ipad app does handle conflict resolution but not the web app. Recording might take some time getting use to since the live program guide only goes for 24 hours and only shows 3 channels at a time. The other interface for programming does have 14 days but it just shows you a picture of the show and you would have to hunt and peck to see what is playing on what day and at what time. It needs a better way to know what is available to record next Tuesday at 8 PM.
Able to get to TV- This is really good I can get recordings and live TV to my TV with my new Roku 3. I had a very old Roku that I had to upgrade. My old Roku had 64K in memory and you need one with 256K.
Able to record all new episodes of a show- So far so good. Has recorded everything as far as I can tell. It has not been over 2 weeks yet so I can’t tell if programs outside the 2 week window will have no issues.
Able to record 2 shows while watching a recording- Works great
Sharing capability for multiple users- Not yet supported. It doesn’t even show if you have watched a show. If you stop part way through a recording it goes back to the beginning and not where you left off.
Skipping commercials- it used skipping instead of fast forward. You can skip at a very fast rate but I’d only recommend to do so to get many minutes into show. I do like the counter with the fast forward it makes it easy to skip a desired number of minutes. It also can go forward with the right arrow (10 seconds per click on the Roku. They will be changing to 30 seconds to match the ipad app. I spend much less time skipping with Tablo than I did with cable.
Changing channel lag- I saw this on one of the reviews. I think they fixed this prior to my purchase.
I did the first review on NewEgg, though it shows Anonymous. I am a little surprised there aren’t more reviews there, but I am glad I could help, @a9erfan. You have a good review here as well.
@a9erfan - Every Tablo should include a quick start guide, sorry yours was missing one. We’ll be addressing this with our manufacturing team.
oh yeah i had forgotten to review mine i think. Will DEF do that!
Yes if you have not put a review on newegg definitely do. There are a lot of people out there frustrated with their current solution and would like to hear your story regardless if you like or do not like.
Alright, I got my Tablo today and so far I'm really liking it, very impressed with everything that it can do, even though I do not have an Android tablet or an iPad, I have still managed to enjoy the experience.
Basically I
have played with TabloTV through my Roku, my Windows Tablets and through my
Windows 8.1 PC, first impressions have been good, super impressed with the
speed, feature set and overall responsiveness of the device, I also like the
looks of the hardware, very sexy looking with a very small footprint, very
appealing to most people’s tastes.
The video quality is stunning! I can’t really tell the difference between watching directly from the antenna hooked up to my TV and when watching through the Tablo stream, good work Nuvyyo, you did a good job, really good!!
Particularly
I’m extremely pleased and overly impressed with the amount of channels that the
Tablo can pick up in my area, I couldn’t believe it while I watched it scan for
new channels, when it finished it had picked up 74 channels! Sure some of those
are crap channels and some are the same networks on different channels for
different areas, but still I’m very happy with the tuner this thing comes with,
a weak tuner it’s one of the major deal breakers for me when it comes to OTA DVRs as I have invested in a good OFF-AIR antenna and good cables etc.
However
there are few things which I immediately noticed in just a few hours of playing
with it that I think need improvement, however again, keep in mind I have
mainly watched on my TV through the Roku box, among those things I can
count the following:
1- ) No way
to record a live program while watching it.
2- ) I can’t (Never mind figured it out :-) )
find a way to delete recorded programs from the HDD, am I missing something?
3- ) No on
screen channel guide when watching LiveTV, having to go back to the guide to
switch channels is no fun and takes from the overall experience.
4- ) While
browsing through the LiveTV guide (This time on my PC using the Chrome browser)
I have noticed something very annoying, if you want to do a little channel surfing
and let’s say you click on a channel then press the back button to go back to
the Guide you are returned to the very top of the guide, that’s most likely
Channel 2, you must scroll down the page again to whatever area of the guide
you were before to able to tune to your next channel.
5- ) For some
reason, not all channels that I can watch on the PC or Windows Tablets are
available on the Roku app, I guess the Roku app still needs work, that’s a real
bummer as I plan to use it with the Roku the most.
6- ) Please add support for Windows 8.1/RT modern apps and Windows Phone if not much asking -) I knew this was not there but I keep hopes that at some point you will think about it.
7- ) Finally
but not least something I knew before hand, but I say again so that developers
don’t forget it J please create some
type of alternate authentication process (Not just pairing) so that TV can be
watched remotely without the remote device having to have been on the local
network at some point, this can be a deal breaker for many people and it’s
currently my biggest issue with the Tablo as I want to allow some family
members to watch overseas, do not remove the current pairing method though, it’s super easy for people, virtually it configures on its own but adding the alternate method is a most for people like me.
That’s it for
now, very happy with my purchase no buyer’s remorse at all, looking forward to
the improvements coming ‘cause I know they are.
