We’ll do that when we add an HDMI port =))
Random observation on the channel scans: so far for me it’s been either 5 circles (green), 3 circles (orange) or 1 circle (red).
Can it ever be 2 or 4 circles?
I resolved the issues I had with the Chrome interface by re-synchronizing Tablo with Chrome (thanks tech support!) and all seems to be good now with managing recordings and schedules. There’s definitely room for improvement on the UI (especially resolving conflicts!) but it’s definitely usable. Seeing 50+ shows with coverart and name on a single screen and being able to recorded individually (or a season’s worth) in two mouse clicks still blows me away. Well done!
@Max - You’ve got an eagle eye.
@earlyretiree - Thanks for that lovely note (and for sharing it on Facebook as well). We’re so glad you’re both loving Tablo!
So far it has been great. I also tried SimpleTV at the beginning of the year. That was a big failure, so I sent it back. But in the Simple TV forum I heard about TabloTV so it worked out in the end. Now I am waiting on the second unit to ship so I can resolve the conflicts. I will be shutting down MythTV after almost 10 years. Sorry to see MythTV go but TavbloTV is much easier for the wife to operate. And cheaper in the power requirements.
Not impressed. I set it up as the instructions stated, but have had nothing but issues. Initially it tried to locate me as somewhere in New York and when manually choosing a zip code, it stated it couldn’t be found. Finally, I let it search where it wanted, then changed the zip code and it worked. It also asked to format the hard drive, but since then, it always tells me hard drive temporarily unavailable…temporarily? It’s been like 2 or 3 days now. I went and tried to set up recordings and get them all lined up. I could even see where there was conflicts, but I couldn’t figure out what the recording was conflicting with??? I deleted recordings for the conflicts. After it appeared a few things recorded, I tried to watch one, and got some commercials. When attempting to move ahead, it got all messed up and now continually get an error on my tablet when trying to view a recording. Even when I go back to my recordings, I now have a “!” where the Play button is on all of my recordings. I decide to do a factory reset. When I did, it did start back up like first setup, but when I got through the channel setup (better than first time), it still shows my recorded shows and those scheduled. The factory reset should have deleted those. I now get a player error, channel does not exist when I go to Live TV and select something to watch on my PC browser. It’s incredible. Everything is hit and miss and it is not meeting my expectations as I have dropped a ton of money on an antenna, a hard drive, and the device. I think it would be cheaper to just go back to cable. Someone help me while I try another factory reset!!!
Another factory reset…same result.
@jploggie have you submitted a support request to Tablo? Looks like they have been quick to offer service.
@jploggie - That for sure sounds like a hard drive problem. It’s likely that your drive is unsupported. Send a note to support@tablotv.com and they’ll get things sorted out for you.
I’s using a Seagate Expansion 2TB Desktop External Hard Drive USB 3.0 (Model: STBV2000100). If it doesn’t work, I guess there is no problem dropping another $100 into this new technology to get it to work. I still have to buy a Roku box to watch Tablo on my TV…another $200. I think I have a total of about $500 into this new toy. is it worth it?
And can someone please tell me what 2TB HD I need to buy so I don’t invest in 6 more before I find one that works with Tablo?
Here are their recommendations: http://www.tablotv.com/blog/back-away-from-that-flash-drive
Thanks for everyone’s advice. I have now ordered the Seagate Backup Plus Slim 2TB Portable External Hard Drive with Mobile Device Backup USB 3.0 - (Model: STDR2000100). Hopefully this one will work. I guess I now have two backup desktop hard drives and one for the Tablo. I will provide an update once I get the new hard drive in the next couple of days.
I wish you would have read a few “hard drive” threads around here before buying your hard drive. The seagate backup plus drive didn’t work for me at all. I purchase a 2 TB toshiba something or other (begins with a C) for $89 at staples and it’s been smooth sailing ever since.
Also you should be able to purchase a Roku box for $100 max.
Is it work it? Yes! I’m dropping my cable and will be saving about $130-$140 per month.
Well I did read the threads and the only difference in the one I JUST purchased is that its 2TB and not 1TB. I guess I will return that one and find something else.
So, now I have purchased a Toshiba Canvio…@jwhitesel…is this what the “C” was for? Got it on Amazon for $65.
