Wanted to start a thread on first impressions. If you’ve received your Tablo, want to hear what you think about it. I’m currently configuring mine. Configuration is fast. OTA scanning is fast. Now formatting my drive so that I can record shows.
So far, so good! It took me a few minutes to find the LiveTV guide that I was used to seeing…you know, the “cable/satellite” guide view like DirecTV or Dish.
So far so good!
First impressions: I’m very impressed
Appearance
The form factor is smaller than I expected. It’s solid. All good here.
Setup
I’m using a wired connection, and a computer, Samsung Smart TV, and Samsung smartphones. I tried using Firefox, but firefox will not connect from the PC. The Tablo recognized my harddrive right away (Toshiba Canvio 1.5TB). It showed me the channel listings, I chose which ones I wanted to add, it downloaded the latest firmware.
And again… the Tablo asked me to format my hard drive, and again I hit format (I’m guessing the firmware update interrupted the format process, no biggie, but would’ve been nice to know). Until the drive is formatted, you can’t use the Tablo. The format probably took about 20 mins.
Tablo Connect, for out of network streaming, needs to be manually enabled via settings.
Tuners
The tuners are sensitive. The two channels which my TV struggles with (poor reception), work very well on the Tablo.
Computer Use
I could only add some TV shows, I’m guessing the channel guide data didn’t fully come in yet…
Other than that, with Chrome, there are no issues.
Samsung Smart TV Usage
I can get onto the my.tablotv.com website, it detects the Tablo, but it hangs when I try to connect to it (says “Connecting” with the spinning circle)… o well, that would’ve been nice.
Smartphone Usage
Worked both in-network and after it was paired.
Though I get a message “You are running a version of Android that supports playing Tablo video in the Android video player. Launch the video player using the button below.” That’s great, but when I launch the video in the designated viewer, I don’t have pause/rewind/etc. functionality.
Roku Usage
Roku works fine. The rewind/fast forward displays on screen as expected. Streams well, etc.
Noteable
I like the guide, it showing you exactly what time it is and how far along you are
I like that I can click on a show and it’ll not only show me the next episode on the “primary” channel, but it’ll search for the show and any episodes available on ANY channel. Impressive.
My only Issue
I paused live TV, through the computer, and there is no “live” or fast forward button. If I use the keyboard, then yes, I can skip forward or back, but it’s not intuitive, and I don’t see how far back I went in the episode on the screen (i.e. with my current cable DVR, if I hit pause, it’ll show me that I’m at 5:43 of the 30:00 episode). On the Roku it works fine, similar to my cable DVR.
So far it’s been good and bad for me. Setup went pretty easy, scanned channels came up fast and the guide info loaded relatively quickly. The quality on the ipad looks real good for a wireless connection and it also looked good on the 61" TV thru air play on the Apple TV. I then went to the roku and I had already loaded the “channel” in anticipation and low and behold there it was. My roku is wired and it streamed live tv well and the quality was good.
Now the bad, the tabloid has yet to recognize my hard drive, a brand new seagate backup plus, 2 tb. It just says " no hard drive connected ". I’ve disconnected the HD, unplugged it, turned on and off, nothing. I then reset the tablo hoping it would recognize, powered down the tablo, and still nothing. Not sure what the problem is.
I then tried to stream a show on the roku and the ipad at the same time. No dice. The roku started to stutter and stop and the ipad said “weak signal” even though I had three wifi bars on the ipad. It might be my network so I will experiment with this a little more.
If anyone has any hard drive solutions that would be great. I’m evaluating tablo as a possible cord cutter device, but I haven’t cancelled the Fios yet.
@jwhitesel - Could be that your drive is reporting the wrong sector size. Regardless of being well within spec and a recommended brand, randomly some drives report 4K sector sizes vs 512. There’s no way we’ve found yet to anticipate this but are working on having Tablo recognize these differently formatted drives.
Thanks for the response Tablo. I think I can connect the hard drive to my computer and format the hard drive for different sizes allocation units. I will give that a try, the only thing I see with 512k is a file system of “exfat”. I’ll try it and see what happens.
A lot of good feedback here! I’ve finished with my basic set up. I currently have it on my local network via powerline adapters. Needed to move the Tablo to the second floor for better reception. CBS channel wasn’t coming in as well. I’ll probably stop by Fry’s and get one of the new Mohu Curve antennas. Those seem to have great reviews.
Adam - Try making sure your Apple TV is running on the latest firmware and that it’s been recently reset. Most issues we’ve seen with Apple TV can be resolved with those simple things.
In first 24 hours I attempted recording 10 shows. My results:
So far, I’m very impressed. I was a gen1 SimpleTV owner, and this thing zips along at a much better pace. Setup was smooth for me with one minor exception - For some reason, my roku3 wouldn’t initially see the Tablo through a wired connection. Once I switched to a wireless connection (in the Roku), it was found immediately. When I switched back to the wired connection, it then found the Tablo without a problem. I sent in a support ticket to ask about it, and they were quick to get back to me to help troubleshoot. Big thumbs up on support. We also have a Roku2, which works fine, and an original Roku that doesn’t seem to work with the Tablo app. Our original Roku is a very outdated unit, so I wasn’t expecting much there.
Wouldn’t recognize a brand new Seagate Backup Plus drive - had to repatriate an older 2TB Seagate GoFlex. No problems after swapping out to the older drive.
I received mine Saturday, and I liked it so much I felt comfortable cancelling DirecTv yesterday.
I am really impressed at the quality I’m getting on my Roku 2 and Roku 3 (both using ethernet). I cranked up all of the settings and even on my 120" theater screen I can’t tell the different between plugging directly into the antenna or streaming from the Tablo. Great job guys / gals. While I would love to have a way to more quickly change channels on the roku other than UP, then selecting a new channel, I get it. Roku has never been known for allowing great dev software for app makers to work with. The part that really makes me smile is that I can just turn it on a channel and walk away from the remote; the channel will stay on all day or until I turn it. With Aereo, it would stop after each show. That made watching a single channel a nightmare. Tablo solves this.
Thanks @Frostcall - we’re pretty proud of what we have and are working hard to make Tablo even better.
When you say you get less channels, is it that the channel scan didn’t find them? Were they marginal (fuzzy) to begin with? Just wondering!
The signal on my TV is low but it picks them up with no jittery images. It’s likely that my TV simply has a better tuner. Channel scan on the Tablo does not see them at all. My TV’s tuner shows me several more channels that are simply unwatchable whereas the Tablo seems to take a ‘smarter’ approach and only show channels that it will be able to show without issue. This is probably wise.
My suspicion was confirmed. As stated previously, the channel I could not pick up was weak on my TV and not showing at all on the Tablo. I spent a little time re-positioning my DB8 antenna in my attic to get the best signal possible and now it comes in clear on the Tablo with a solid signal.
Amazing! We specifically chose really good quality tuners so I was surprised that your TV was getting good quality signals and we weren’t.
But you’re right, we don’t show channels that don’t have a strong enough signal because it’s not going to result in any useable recordings. And who wants that???
Hey @TabloTV you think you could speed up the super fast channel scan? I mean, under 30 seconds is just too slow nowadays… just kidding!
