Thanks!
So then there is no upscaling of the resolution, 720p 60 fps content is being recorded as 720p 60 fps at the 1080p setting.
Thanks!
@TabloTv said this, âIn order to get the 60 FPS, you must record at the 1080 setting which will capture 720 @ 60 FPS when possible.â
I removed some Tv shows that were on Fox from my Tablo using surlatablo.py.
This is what Mediainfo shows:
General
Complete name : Y:\TV Shows\Watch And Delete\The Peopleâs Court\The Peopleâs Court - s19e05 - Bitter Exesâ Bedroom Battle.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.83 GiB
Duration : 1h 5mn
Overall bit rate mode : Variable
Overall bit rate : 6 203 Kbps
Collection : The Peopleâs Court
Album : The Peopleâs Court
Track name : Bitter Exesâ Bedroom Battle
Genre : Reality;Law
Description : People resolve grievances in small-claims court.
Recorded date : 2015-09-11
Writing application : Lavf56.18.101
Comment : People resolve grievances in small-claims court.
LongDescription : People resolve grievances in small-claims court.
Part_ID : s19e05
TVNetworkName : KFXV-DT
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 5mn
Bit rate : 5 934 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 fps
Minimum frame rate : 59.920 fps
Maximum frame rate : 59.960 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.107
Stream size : 2.71 GiB (96%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1h 5mn
Bit rate mode : Variable
Bit rate : 254 Kbps
Maximum bit rate : 261 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 119 MiB (4%)
Language : English
Here is one for the wife. It was recorded from a 1080i source.
Medinfo shows:
General
Complete name : Y:\TV Shows\Watch And Delete\Rachael Ray\Rachael Ray - s09e180 - Chef Curtis Stone Is Rachaelâs Co-Host, and Theyâre Giving You the 411 on Everything From Food to Fall Organizing!.mp4
Format : MPEG-4
Codec ID : isom
File size : 4.60 GiB
Duration : 1h 5mn
Overall bit rate : 10.1 Mbps
Collection : Rachael Ray
Album : Rachael Ray
Track name : Chef Curtis Stone Is Rachaelâs Co-Host, and Theyâre Giving You the 411 on Everything From Food to Fall Organizing!
Genre : Talk
Description : Co-host Curtis Stone makes a poached-eggs breakfast; chicken pepperoni; organizational expert Peter Walsh shows how to make a bed to get a better nightâs rest.
Comment : Co-host Curtis Stone makes a poached-eggs breakfast; chicken pepperoni; organizational expert Peter Walsh shows how to make a bed to get a better nightâs rest.
LongDescription : Co-host Curtis Stone makes a poached-eggs breakfast; chicken pepperoni; organizational expert Peter Walsh shows how to make a bed to get a better nightâs rest.
Part_ID : s09e180
TVNetworkName : KVEO-TV
Video
Format : AVC
Codec ID : avc1
Duration : 1h 5mn
Bit rate : 9 821 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Frame rate : 29.970 fps
Minimum frame rate : 29.970 fps
Maximum frame rate : 29.980 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.158
Stream size : 4.48 GiB (97%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 5mn
Bit rate : 254 Kbps
Maximum bit rate : 259 Kbps
Stream size : 119 MiB (3%)
Language : English
Hope some of this helps.
Thanks. So the 720p 60 fps source content is recorded at 720p 60 fps when using the 1080p recording quality.
And it is the playback of the 720p 60 fps h.264 video that is causing problems on the Roku.
That is correct.
But if I remove the shows from Tablo & play them in Plex on the same Roku3 or Roku TV they play fine.
They are Direct Played. No transcoding.
How are you removing / extracting them?
Iâm using the script from âcjcoxâ. His surlatablo python script.
I see. I know all these methods that use ffmpeg to extract the recordings are not leaving the video untouched.
ffmpeg is in fact reencoding the video so thatâs likely why it plays back fine.
I know for sure Jestepâs Tablo Exporter does not leave the video untouched. It is a great tool.
Thanks, I finally found it.
Any news on this issue?
I asked to be part of the trial, but never received any response, acknowledgement, etc.
Same here, but no reply for me either.
Saw âLoading, please wait.â on the National 19 times last night.
My wife is asking me why we are putting up with this.
This is not goodâŚneed update or the tablo might be moving on soon.
If you are in fact using the 1080p recording quality and your issue is not network related, then switch the recording quality to 720p and it will fix the problem.
This is a sure fix until Tablo fixes the 1080p issues.
My wife and yours are in the same camp and pressure is building to go get at least basic cable. She is invoking the old common sense question - âWhy canât they revert back to the earlier build?â There is likely a technical reason for not doing that but that certainly was our Tablo âHappy Place.â Right now life really sucks when it comes to TV watching - thank goodness for Apple TV.
You keep saying that, but the experiences of @jayeffgee and @oldmike donât seem to agree. It seems to me that 1080p may be a factor, but itâs not the only factor. And too, changing the recording quality wonât do anything for existing recordings.
Well there has been no change in how 720p recordings are done at the 720p recording quality in 2.2.2 (from what we were told anyway). As well, I continue to have no playback issues on the Roku with 720p and others have reported the issue going away when going from 1080p to 720p, so my assumption would be these individuals have other network issues.
Options are always goodâŚlike the option to revert to the previous firmware!
Network issues that just happened to occur coincidentally with 2.2.2?
