@Nick I scanned through this thread and did not see the brand and model number of the modem. Can you provide this info?
I tried to find out which Motorola canopy modem it is using the power supply details but I couldn’t.
You could go up on the roof or ask the ISP what the model is. As well if it’s even possible to access its configuration page.
@Nisk So theoretically if you plug that into your PC instead of your router you should be connected directly to the Modem.
I logged into 192.168.100.1 the screenshot is below
This link says that a Cambium device uses username: admin password: Password. http://doc.azenn.com/cambium/CambiumPMP450_InstallationGuide.pdf
This link says to try blank/blank or root/blank. http://community.cambiumnetworks.com/t5/Other-PMP-Solutions/what-is-default-user-name-a-password-on-a-900mhz/td-p/14316
I may have missed it earlier in the thread, but is there a reason why you chose such an unusual ISP? Perhaps no other options available?
If you are in Southern Ohio, I hope you are surviving the snow tonight.
Playing with your modem settings could screw up your internet. Just FYI
With the modem outside you have no way to factory reset it.
I found and downloaded this document and did a search for Bridge. Page 435 shows your screen shot.
Yes bridging different networks like the wired network and wireless network is very different than bridging the modem and router. In my first case, bridging can refer to connecting multiple LANs, which is not what we are discussing here.
What we want is bridge mode:
“Setting your modem to Bridge Mode will cause your modem to stop acting as a Wireless Access Point and router, and instead it will act simply as a pass through modem. This will allow you to use your own third party wireless device if you prefer. Once converted into Bridge Mode, you will not be able to utilize the wireless features of the Modem, and you will only be able to use as many ethernet ports on the back of the modem as you have IP’s registered to your device (typically this means you will only be able to use one or two ethernet ports simultaneously).”
In the OP’s case it is one IP and one device (his ASUS router). But that still doesn’t explain why he needs the ISP to provide him with a Static IP.
Thanks for all your help, folks.
What is your upload speed on your Internet anyway?
It could be a moot point about setting up Tablo Connect if it’s too slow. Too slow and the video quality won’t be good.
@theuser86 Yes I am aware of what bride mode is.
I figured you did, my post was more for others reading this thread so they don’t get confused.
Once I have been faced with the same trouble, I found the manual site named Manualbirds, where you can view and download thousands of free PDF manuals, guides, and handbooks online. Here is the clink for the ASUS RT-AC56R manual: http://www.manualbirds.com/manuals/asus-rt-ac56r-user-manual-140583
