Finally had to do a power-up reset and firmware update, and it is now working. Thank goodness!
Glad to hear they fixed you up.
- What is a âpower-up resetâ?
- Which firmware are you running now?
While the tablo unit has an actual reset button it is unclear if this is a full power reset or a fast reset. A full power up reset would reset all the controller chips, such as the usb controller, on the mother board.
If you followed the thread on the disk problems associated with out of date disk firmware it would appear that the reset button didnât clear the usb controller since it was in the same state as before the reset. But either pulling the usb cable or pulling the power cable cleared the problem
There are, I now know, 3 reset methods:
quick push - normal reset. Nothing lost
push several seconds until LED flashes - you lose your schedules and recordings
unplug power, hold reset button and keep it held as you connect power and wait for LED to flash - this seems to be a full factory reset, and I was prompted to update to 2.2.2 when I connected again. Started from scratch of course.
Thanks for enlightening me.
Reset method #2 results in losing recordings but not reclaiming the disk space!
Is that also true for reset method #3? Were you prompted to reformat the drive?
Canât really answer that as my HD was malfunctioning and I had to use a new one anyway.
Sorry
