Billy Joel Live and Tablo can't play it ? 9pm EST
3 days later… its your reception.
Nobody appreciates a ‘know it all’.
For your information I’ve had this Tablo Gen 4/4 for 4 months now and this is the first time I’ve had this issue. So forgive me for thinking it was not a signal issue.
re splitters: would this work ?
Here’s the fan I bought at Target: Honeywell Black Turbo Force Power Table Fan, New, 6.3" L x 8.94" W x 10.9" H, HPF820BWM - Walmart.com
thanks!
I don’t think this splitter would work. In my situation, the coax from the antenna is male. You’ll need a female connection to that. And the 2 outputs would have to be male.
Yeah, I would just go a standard splitter if you want to try @Ron1 suggested and avoid splitter cables.
You can have intermittent tropospheric interference. There is a web site that gives forecasts out to a week.
I think it defaults to center-to-east US, but you can use a dropbox in the upper left to change to a different area.
This is for the center-east US:
This is for center-west US:
However, the 4th Gen guide was corrected later that same day.
