Apple TV deinterlacing
This setting is necessary on the Apple TV and must be reversed depending on what channel you’re watching. This setting does not exist on Google, webOS, and Roku and is not necessary on those platforms. Can the Apple TV version be enhanced to perform better like the others?
what does this feature do? I have a new apple tv 4k should this feature be on or off
Depends on the channel you’re watching. On Fox and ABC it should be set one way, and on the others, the other way. When you’re watching motion and it’s stuttery, then you know you need to switch it the other way. But on Roku etc, this is not necessary.
