App for streaming on PC
Is Tablo working on developing an app that will allow users of 4th Generation to stream recorded shows on their PC? If so, is there an ETA?
One comment thread on the PC potential… View Tablo on PC
OK. but tablo needs first to get existing features to work properly, then move on to new ones.
I suggest you try watching Tablo on your PC via BlueStacks or another Android emulator.
Thanks - I was able to get it to work just now by using the LD Player emulator. I had heard BlueStacks wasn’t working for Tablo, and I found an old comment from last year in this Community that suggested LD Player.
Tablo thru Bluestacks works great on my Mac. Not sure about a PC.
Tablo through Bluestacks on Windows 11 is working fine here.
I can see why there might be some confusion. I had Gen 4 Tablo working fine in Bluestacks, but had to reinstall it. I also am running a Legacy Tablo. When reinstalling Gen 4 in Bluestacks, I had a question about whether Gen 4 uses a different account than Legacy. (Still am not sure.) But when I asked the Tablo AI help-bot about reinstalling on Bluestacks, it told me: “Unfortunately, the Tablo app for 4th Generation models is not compatible with Windows 11, including when using Bluestacks. The Tablo app for Windows is only available for legacy models.” Humbug.
