Struggles/challenges I’m fighting here - window sizes, columns, column width, resizing columns… column width. Already covered the bug adjust one windows, the another is completely screwed up.
I believe I recall a plans for a settings for these - awesome! I’m not sure if it’s a java thing or varies across platforms. Now I’m over my head, these are modal windows, in that they are missing min|max controls, and they overlay the main, but can still be minimized.
Recorded opens max, I can read virtually every column. Length is twice as big as need, due to it’s title, pushing the last column off, dreadful horizontal scroll.
Scheduled and All Airing both open about 2/3 of the screen width. The Description is all but useless, as I’m not sure how big it needs to be read it. Might be my system/settings. Both have first and second way too small to read - date/time and title!
Here’s some goofy stuff. I eliminate the ones I don’t want, open the windows size. Close the columns with excessive white space, when I stretch out smaller ones - they all adjust somewhat. So I have to readjust the ones that are too big again, so I can open up the ones that are too small.
Now shows at least open full width of my screen. Every column except description is wide enough to read it’s contents. (for the few show that do have a quality, I don’t know who/how that’s decided)
As discussed, if before, if opened individually and adjusted coming back to another seem to screw things up. So opening all of them is a pita, having one sized up just right, closing it and moving on, then going back…
Resizing even one - just to check something… doesn’t feel worth the bother. But, if I plan things, because there is great benefit to using APL Tablo - and I know it’s still under development, just sharing my experience.
