@TabloSupport Well the issue has returned, unchanged this Sunday morning… around 2am all recordings failed with the “crossed out play icon”. I noticed it Sunday evening, powered off the Tablo and disconnected the hard drive, took it to my PC and performed another HDTune drive check… 4hrs later, it passed with no faults found.
I’ve had the same issue happen 3 times since I received my 20-tuner unit. It happened again sometime on July 4th. Guess it wan’t to observe the holiday as well. If I unplug/reset my Tablo, it seems to work fine again for a while… but I never know when it is going to happen next. Kind of frustrating. Think I’m going to start resetting it every Sunday morning as a work around until it gets resolved…
above post should state 2-tuner unit.
@jkline - The problem is the same - I think it is interesting that the scheduled recordings fail, but you can still watch live TV even on the channels that had failed recording AND you can record a show from the guide. That would lend me to think it is the scheduled recording engine and not a tuner itself that is failing - UNLESS maybe the scheduled recordings are linked to a specific tuner. If that tuner locks up then the scheduled recording fails. Live TV handles the locked tuner better, falls over to an available and working tuner, etc.
@mtuckman @TabloSupport That sounds right mtuckman… the scheduler.
I had failed recordings last night ad well.
Just received my Tablo and brand new wd elements drive and I am seeing this issue. Pretty frustrating when you depend on it to record shows after cord cutting. Did anyone every get resolution on this? I opened a ticket, but just trying to figure out if I need to just put right back in the box…
The next firmware after this was going on, largely addressed this.
OTA is a finicky source for reliable content access. You very well, could just be dealing with a weak antenna, poor terrane for signal pickup, and/or weather variables that interrupt your OTA signal. Maybe… Just maybe… Power loss to your Tablo could explain the issue… If you really are seeing all shows fail. It’s stupid, I know… but it might still happen under the new firmware.
Tablo says the iPad app includes some explanation for why the recording has failed… They also say, that feature will make it to other platforms in the future. That will be cool.
