@shhern WRT, “It was also not broadcaster issues as I was watching the same channel on Live TV…”
Was the live TV via the Tablo? If so, it’s not the same problem we are reporting in this thread. Watching live TV yields a “no signal” message and a reboot – which clears the problem.
OK, new insights. I think I know the cause (hardware), what is at fault (Tablo for lackluster implementation of its file structure), why this was so confusing (Tablo dev has no fault/recovery processes built-in… the unit just reports “crossed out play icons” until the fault is cleared or lost due to a Tablo reset/power cycle).
@Thumbs - It will be interesting to see if others have bad sectors. I keep a WinDoze machine around; so I downloaded SeaTools and had a look. The basic quick and short generic tests found no issues, so I’m running the long generic (which will take some time).
Seagate Backup Plus Slim 1TB here. I thought that the hardware managed the allocation of bad sectors, and that extra sectors were kept in reserve as replacements. Maybe the Tablo file system/access method somehow interferes with this?
@jkline Yup, that’s my theory.
Wow, thanks for all the research Thumbs. When I get my Tablo, at least I’ll have a clue as to what is going on if things get wonky.
@jkline No, it was with the tuner in my TV but using same antennae. I still believe it is the same issue mentioned in the first post as during the "lockup" any new recordings showed up as crossed out. It would show them in the web interface but not the Roku. It is possible the unit reset at some point and the recordings started to work again.
I'm using a WD drive on my unit and will try to look into the sectors if I have time tomorrow.
Great to see some of you guys digging into things deeper.
Noticed an issue this morning that might be related to this (beginnings of the problem that worsen over time?). I have been on the lookout for failed recordings and found one this morning from last week on channel 20.1 (720p). I tried Live TV on 20.1 and instead of the Tablo resetting like I was expecting it came back with an error, unable to tune channel (reception issue). Ok, I go to my TV, go to 20.1, comes in with no problem. Go back to the Tablo and try 20.1 again, and then 20.2 (480i) - both failed (live tv and recordings). I then tried some of my other channels and those all worked. WTH? I was going to power cycle the Tablo, but instead I decided to do a rescan of the channels (all channels showed 4 green dots before rescan). I had to rescan a few times because the channels that were checkboxed didn’t want to show up on the Settings page (maybe that’s another issue, or maybe I had to wait for a refresh). Anyway, long story short, after rescanning the channels, 20.1 and 20.2 now work fine (live tv and recordings). I did not touch the antenna feed. Because this was limited to only 20.1 and 20.2 you could say it was a broadcaster problem, but if so the Tablo is not handling it very well. I am not an expert in television broadcasting, but what could a Broadcaster change that would “break” that channel on Tablo?
@mbellaire - " I had to rescan a few times because the channels that were checkboxed didn’t want to show up on the Settings page (maybe that’s another issue…"
That is another issue. I reported it on my 4-tuner. I was told I was the first to report it. In any event, I’m sure they will work it out over time.
@TabloSupport - @mbellaire & @streambird (in the “Guide Data Not Downloading” thread) are reporting the same issue I reported in ticket #1010. You might want to reopen it.
Y’know, all these guide data issues and recordings getting botched are very disconcerting. I mean, I expect there will be a few bugs, but for something that you want specifically to time shift, lost/corrupted data is a real concern (to me, at least).
@VegasSteve - I share your concern. The first months I had my Tablo it worked great (the software was a little rough around the edges, but it worked). Now these odd errors are popping up. Someone in another thread thought that the 2.1.10 firmware might have something to do with it, but who knows. I have high hopes that the Tablo folks can get things straightened out because I really do like the product. They don’t want to get too close to the reputation “tipping point”. @TabloTV - I know you have been working on manual recordings, but are there any stability updates in the pipeline?
Agreed, stability is frustratingly lackluster. My Tablo locked up sometime between Saturday night and Sunday morning for the second time since I got it mid May. I am using an “Enterprise” 2TB drive (MK1002TSKB) that shouldn’t have any bad sectors but not ruling it out. Wish there was a way to see to log errors for user end troubleshooting @TabloTV
Well, the scheduled recordings this morning failed, and yet I was able to manually record on the same channel right afterwards.
@mtuckman - the problem reported in this thread is that all scheduled recordings fail until a reboot. Attempting to view live TV results in an error message and a spontaneous reboot. It doesn’t sound like the same issue to me. Have you tried to view live TV? Also, what is a manual recording? Do you mean a single show rather than recording all in a series?
