I had a problem that tech support corrected.:Below is the text from support: They said a new version is out soon…When?
Hey Tom,
I was able to manually fix the database entries for the recordings you were having problems with, so the ones you’ve recorded but haven’t been able to see should now be visible, and your recordings should hopefully record properly from hereon out. Definitely let me know if they don’t and we’ll take another look!
In the meantime, we’d ask that you refrain from deleting any old episodes of the programs you were running into issues with. What I’ve done is just a manual fix, and when our next firmware version is released soon (v. 2.2.20), you’ll be free to delete any programs you’d like.
Let me know how things look on your end, Tom!
Talk soon,
Gotta love relative timeframes.
If they follow the standard process, then it could be days or weeks, depending on the length of beta testing.
There’s usually much more than 1 fix to test in the beta, and they usually add even more fixes, and enhancements before the beta period ends.
I don’t see a new Tablo firmware beta test yet, though.
This sounds a lot like the database corruption issue they had a long time ago, where the database gradually degraded over time. Sounds like it may have reared its head again?
