In Austin TX channel 24.1 gets detected as GRIT and has its schedule. Ceder ark has same problem. The solution until Tablo fixed it is to use 78759
Are there any other locations in the Ad uston or other locations with the same or similar problem. Changing the zip code might fix it. Tablo is draggytheir feet. I have had the problem since 4 tuner 4th gen was available
@tablotv I have given up on “support”. 78759 and 78744 are two Austin zip codes that fix the problem. Btw, legacy detects correct using ,78758 meaning 4th gen uses cheaper tuner.
