I’d like to be able to click on a channel, and have all the shows that are broadcast on that channel display, rather than just the primetime shows.
If I want to browse daytime shows, I have to view the live recording schedule, and scroll up and over, over and over. Very tedious.
@allthatssolid - If you select ‘TV Shows’ then ‘Channels’ you’ll be able to browse shows based on channel. Hope this helps!
@allthatssolid - You’re welcome! I love easy fixes :-bd
@TabloTV, while we have this topic open, point to clarify… is Prime Time local? ie, Primetime in Chicago is 7-10pm where say Detroit is 8-11pm.
