Is there a way to play recorded TV shows from Windows Media Center on my Tablo? I have a bunch from before I started using Tablo. I don’t want to lose the recordings. Any help is appreciated. Thanks.
I dont think so.
@zero610 - Sorry, Tablo can only stream Tablo content.
The Tablo will only play files created on it. But you could use Plex to store both Tablo shows and WMC shows on the same server and watch them with a common interface.
If I use Plex, can I put the show files on the Tablo HDD or does it need a separate location to stream from?
Non-Tablo files cannot live on the Tablo hard drive.
Where you install the Plex Media Server, you should host the files there.
