on my iphone, settings then scroll to apps at bottom of screen and find airport utility and go to bottom of that screen
That did the trick. Thank you!
Since each router is dual band… -73 is the start of low signal on the 2.4ghz and 5ghz.
that did it!! Worked for me… Thanks a bunch @tabjoe and @exwxman95 !!
NetSpot might interest you.
I have the free version installed on my Mac desktops and MacBook Pro.
