I was excited to receive my Tablo 4th Gen from Amazon today. After a few hours my excitement is gone and I’m ready to send it back to Amazon.
- I tried to use it via the PC and it doesn’t work with Chrome, or the Windows app. Reading through this forum it seems that this is normal. Is it really? Is there literally no way to use use this thing with a PC? The docs mentioned using Firefox, but that didn’t work for me either. What a waste of time, they should just remove that bit from the documentation. I tried just visiting the IP in my browser, but I only receive a plain white page that says " Nuvyyo Tablo Server".
- I gave up on my PC and installed the App on my Apple TV 4k. There was only the legacy app in the app store, it doesn’t work. Apparently you need a new app that doesn’t exist. Reading through the forum it seems that we need a new app that will be released “Soon”. The date on that past is more than 6 months ago. Am I missing something?
- I tried to install it on my Sony TV, and it just tells me the app isn’t compatible.
- I can’t find any way to copy the stored videos off of the device. Is there an NFS or SMB share I’m missing, or is the only option literally to physically insert an external disk, and physically move the disk to another system when I want to copy the files off? Does it really not support saving the files to a share?
- The docs say it requires a constant internet connection to function, which would be fine but the other concerns here make me wonder if the company can afford to keep the servers up. Is there some alternative software I can use to use the tuner without the software guide/etc?
