I hope she doesn’t have an older reliable car then.
I gave my 28 year old working car away when it reached 375K miles.
No engine rebuilds.
It still got 30 mpg.
Of course, you could tell her that changing engine oil is passe. ![]()
No engine rebuilds.
sure. I have a Netgear R7000 swapped the stock firmware for dd-wrt. I had used FreshTomato, it’s more user-friendly, but had a strong past with dd-wrt.
I’m not going to recommend flashing firmware… but you may “look into it” if your UI is corny and you think your hardware can do better.
Ah, then you know of what I speak about Netgear Nighthawk UI and firmware. The user given solution to a number of the problems I have encountered was to swap/flash/replace the firmware with dd-wrt or some similar product. I believe that is the correct solution but that is just crazy that the manufacturer cannot fix its own firmware and that users are routinely commenting on the company forum about replacing the firmware.
But we are straying from Tablo, which now works great. I was just going sideways a little to let others know the problems I faced with my Tablo were really other network products not working properly.
