ASUS RT-N56U here with over 30 clients regularly… Always rock solid
I have Tablo plugged into router and wireless Roku 3 and it only buffers with Live TV. Recorded programs work fine. Very annoying when trying to watch live sports.
I use a Roku 3, a Roku XD and a Roku LT. The Tablo app is unusable on the XD. It crashes upon startup every time. I’m not sure if this is just another defect or if the XD is not supported. If it is not supported, I expect it ought not install on that version of hardware from the Roku Channel store.
@vgrund If you have Plex, I’ve found that my XDs Roku can play back recorded Tablo shows via Plex. It still doesn’t have the horsepower to stream in Plex, but it seems like a lot of channels I’ve installed recently aren’t compatible with that old player now either.
Yes the XD is old. I’m pleased Netflix and Amazon still support it. I will still probably upgrade to a 3 because I agree it is getting long in the tooth.
I have a first-generation Roku (N1000) that was given to me many years ago. Tablo crashes on it immediately.
I’m thinking of upgrading to a Roku 2 (3000). It looks like a couple of you are using similar devices, correct? I’m basically looking for some confirmation that Tablo will be supported before I buy the new model.
I have four Roku’s: 2 ea Roku 3’s, 1 ea Roku 2 and 1 ea Roku 2 XD. They all work fine except the old 2XD crashes from time to time.
Thanks Danb!
I’ve had NO problems with a wired Roku 3 in moderate usage.(there’s not a ton to watch during the summer)
I have 2 Roku 3’s. Sure would like a grid view!
@DanB, can I assume you’re using some version of the Roku 2 with HD support, as there’s apparently no way to stream Tablo video to an SD TV?.
Just starting the “cord-cutting” process. I have a Roku 3 on my main TV, connected via 5GHz wireless to an Asus RT-AC68R. So far, no streaming issues at all with Netflix, Hulu, Plex.
@brandtb - We’ve found the streaming stick’s WiFi antenna can be a bit dicey. Some folks have had success and others haven’t had much luck.
We’re looking to hire a Roku dev so we can accelerate the feature velocity on that platform. There is a backwards skip on the Roku but each version seems to have a different time increment implemented via the remote. We’re planning to standardize this.
With the Tablo hardwired and my Roku Streaming stick in a location close to the wifi, mine doesn’t drop a beat. But nothing beats the hardwired Roku3 with the hardwired Tablo.
