Which channel will the Tablo record?
I can get Fox on 2 channels. One is stronger then the other. Does anyone know how the Tablo decides which channel to record? Their schedules are different during the day but Primetime is pretty much identical.
I would like to include both in my guide but I would always want the Tablo to use the stronger more reliable signal when a show could be recorded on either station. The Tablo auto selected both for the guide but from experience I know one channel gives a better signal / reliability.
After you select the show you want to record, click on Options. Under Options there is a drop down for Channels. Click on the drop down and select the channel with the strong reception. Click on Save. The show is locked to only record from that channel.
Thanks, that is exactly what I needed!
Just to add, your Tablo should also choose the stronger signal to record automatically but the advanced recording option is also a great way to lock that down.
