I have noticed a weird problem with how TABLO works (and I think allowing selective recording of a show from specific channels/times could help) (but I also think the show recording selection algorithm needs some work)
![](https://community.tablotv.com/uploads/default/161/1f8be0802e55e54a.png)
the 30 min version of the show should really be its “own” entry for a show to record and not lumped up with the primary 1 hour version.
Thanks for bringing this up - I requested a long time ago that we be able to select recordings from a specific channel only for a show. It was acknowledged by Tablo.
http://community.tablotv.com/discussion/838/smart-scheduling-let-us-choose-the-channel
great idea, would love to see!
Can’t you accomplish what you want to do here with the manual recordings feature that was implemented a long time ago?
Can't you accomplish what you want to do here with the manual recordings feature that was implemented a long time ago?
Thats not fixing the problem.
@ericgus - Interesting.
Not that, but I’ve seen where Motorweek is widescreen on one PBS channel and 4-sided letterboxed 480i widescreen on another. I removed that offending PBS channel from my lineup. And then removed Motorweek from my recordings as I can get to the PBS website for that show. That’s here in the Los Angeles area.
I can add to this that there was a show, can’t remember which one right now, but it got moved from one channel to another. My Tivo picked that up and continued recording.
One issue I’ve seen (may not be likely if Show IDs are different) is where an English and French showing of the same TV show get picked up, e.g. NCIS Los Angeles in English on Global channel 6 and in French on channel 40 get picked up as the same show on different days. Both would get recorded. This was on my previous device and not Tablo. To avoid this I had to schedule “this channel, once per week” and that resolved it.
An HD checkbox would be handy for recording or even viewing the guide. So many movies. Most of them SD, or worse, 4 sided letterboxed SD.
Also, knowing what channel a recording came from or is going to come from would be nice. Sometimes that information is there, some times not. If I keep getting junk SD, I could remove yet another channel. Or avoid recording from it in the first place.
@ericgus To add onto what @TabloTV what was saying:
@ericgus To add onto what @TabloTV what was saying:The duplicate ID's here are the source of the issue. The problem here is that it goes all the way back to the broadcaster. They send an ID to our guide data provider, which feeds to the Tablo, which is then looked at by the smart scheduling logic.The problem is that the broadcaster isn't differentiating between the condensed and full-length versions of the same episode.We're going to take a look at this, but it's trickier than it sounds. I know we'll get a few suggestions on looking at different parameters of the show (the length, for example) versus the ID, but it's unfortunately not all that simple - there's a lot built into the smart recording logic.
Oh no … I realize this is a complex issue … why I wanted to bring it to your attention given its complexity…
@ericgus Oh no! I didn’t mean to sound dismissive or anything, just that we can’t fix this one overnight is all! But yes, thanks for bringing it to our attention
@ericgus Oh no! I didn't mean to sound dismissive or anything, just that we can't fix this one overnight is all! But yes, thanks for bringing it to our attention :D
You didnt! … dont worry… its all good … I figured you guys would find this problem interesting.
The only really annoying aspect of this bug is when it opts to record the 30 min version over the 1hr version and skips the right 1hr version if I dont catch it ahead of time … thankfully they repeat so it hasn’t been a huge problem …
i believe the way tivo does this is to use more than one criteria by using a combination of showID and channel. they may be using HD/non-HD as a criterion as well, but i’m not sure. perhaps @TabloTV can follow this logic on an upcoming update.
i believe the way tivo does this is to use more than one criteria by using a combination of showID and channel. they may be using HD/non-HD as a criterion as well, but i'm not sure. perhaps @TabloTV can follow this logic on an upcoming update.of course, if the 30 minute show appears on the same channel as the hour show, it's a whole different game. and to future-proof potential problems of this sort, additional criteria should be allowed for and implemented as the problem pops up.so allow for showID, channel, resolution (ultra-hd is on the far horizon), episode number, show length, original date aired, rating level (the parental guideline type), live/non-live, etc.this is quite a large list to implement. i'm not saying to implement all of this now, just to allow for it and add each criteria when a similiar problem pops up.
In this case yes… the show is on the same channel just at a different time.
