That’s it. And if you are connected over Tablo Connect, you can’t use the scrubber at all, just pause and play.
@snowcat, I started this thread because it seemed that @TabloSupport thought we should. See this thread
@Jestep Looks like there was some confusion, apparently it’s always been this way, sorry for the mixup!
@Jestep, can you go back and forth using Tablo Connect? I can’t on my Android 4.4.4 phone (Moto G 2014). The scrubber is stuck on the far left, while the clock on the far right keeps advancing.
I am curious if Samsung devices act differently than other Android phones. The Tablo had a big problem with Samsung not too long ago that wasn’t an issue with other brands. Maybe the fix allows the scrubber to work on just Samsung phones.
Does anyone have a non-Samsung Android phone that they can test a recording using Tablo Connect? I want to know if the scrubber bar can be used. Thanks!
