Is there a way to use the web app to access my Tablo quad from outside my home? I have remote access using the android app but I am told the web app is more powerful and user friendly. but when I open the web app at work i can’t find a way to connect to my home Tablo.
Your work computer must be paired with your Tablo on your home network first. Also, some work networks block the necessary ports needed for connecting because of security concerns. You might be able to set up a VPN connection to avoid having to physically pair the devices, but someone else here would have to help you on that type of setup.
