Anyone know what the difference is on this forum? I’ve seen one or the other term used on other forums, never seen both on one forum, don’t understand what the difference it.
This should help you learn more about how this forum works:
@discobot display help
I currently know how to do the following things:
@discobot start {name-of-tutorial}
Starts an interactive tutorial just for you, in a personal message.
{name-of-tutorial}
can be one of:tutorial, advanced tutorial
@discobot roll 2d6
3, 6
@discobot quote
Your work is to discover your work and then with all your heart to give yourself to it. — Buddha
@discobot fortune
You may rely on it
@discobot tutorial
Hi! To find out what I can do, say @discobot display help
@discobot display tutorial
@discobot start tutorial
Well, I read everything there, nothing on watching or tracking, just a bunch of talk about badges.
Tried starting the tutorial, never started.
@discobot start new user
Okay, now I understand, thanks, though this explanation should be in notifications where you select the preferred setting.
