Why does live TV stop and revert back to the live guide??
The only thing I can figure is the TV guide show has changed and the live feed cuts off. Why won’t it stay on the channel and keep running?
@TabloEngineering, sounds like we need a refinement/correction of this situation.
If it is an OTA channel you are watching it means the signal is weak and will revert back to the guide. Maybe try repositioning your antenna?
In addition to the comments by @tandelor, if I’m not mistaken - if you selected the channel in the guide (the first column), it should continue to play into the next show, non-stop. If you selected the show itself in the guide, it will stop at the end of that show.
Thanks for the thought, but it has happened twice right at the top of the hour which coincides with a change in shows. @wysiwyggin - I selected the current show on CBS OTA channel. I didn’t know there was a difference in selecting 1st column vs 2nd column. Thanks.
I have found this to be the case only if I happened to be recording that program while I am also watching it live.
