I think it would be a great idea if possible to add both. (Side note: I’m waiting for mine to be delivered so if you can already watch live tv & check tv listings at the same time then just disregard) I have a Apple Tv 4K & I cant wait to get this set up.
I just use my phone/comp/tablet as my pip. depends on what I have the closest at the time.
Cool seems like that will work. Thanks for the reply
I finally got it and am loving it. Point blank period.
Depending which device you’re using - HTPC. Firefox comes with Picture-in-Picture. Click on it, change to the tab with, for example, TitanTV and check your listings.
and not miss the weather report. It’s resizable and movable.
Truth be told (I have not done this for Tablo), but the way TitanTV works, if you have api access to the Tablo, in theory you can at least change the channel via the TitanTV i/f. Scheduling might be a bit more difficult (you could do manual recordings via the api that way though).
