Video Freezes while playing a recording
Since we started recording (4th Gen) we have encountered a problem with the playback on a lot of them. The video freezes and the audio continues. It doesn’t matter what you attempt to do: ff, rewind, pause, move thumbnail in any way - the moment you touch something on the remote it jumps to the end of the recording! I have begun to pay attention and keep track of exactly where we are every time I ff through a commercial. It’s a pain :face_with_spiral_eyes:. Anyone else experiencing this? Anyone working on the problem? We have a TCL Roku TV. I just saw a couple posts that are similar, but I don’t see any fix in the works.
Do you use an external drive for your 4th Generation Tablo? If so, it may be viable to disconnect and then reconnect it, just to verify there’s not a loose connection or cable issue.
If that fails, consider reaching out to our technical support team: https://tablotv.com/support/#contact . They should be able to help.
No. We stopped using an external drive when we went from Legacy to 4th Gen.
We have the same exact issue with a Tablo Gen 4 and TCL/Roku tv. No external drive is being used. TV signal is 4 green dots on all channels.
Back in April I submitted a post about this problem including the following:
I’ve also observed the exact problem you mentioned regarding the picture freezing with the sound continuing and the status bar at the end of the show. In my case the sound eventually also stops after a couple minutes. This occurs on my TCL Roku TV (TCL model 32S327 using Roku model 8116X ). When I place a Roku Streaming Stick+ (model 3810RW or 3810X) into an HDMI connector on that same TV, and switch the TV input to the stick, the problem disappears. I have another TV that isn’t a TCL Roku TV. When I use a Roku stick on that TV the problem doesn’t exist.
This has occurred on all Roku software versions (since at least April) through 14.0.4 (and app version 0.8.801 - 734366). This seems to be specific to TCL Roku TVs. Once a recording is found that has this problem it always occurs at the exact same point in the program during multiple replays. It is not an intermittent condition. It may originally occur when specific signal conditions occur (possibly transient weaker signal glitches), even though the scan shows four green dots. I believe I’ve also had it occur on live programs, though not as commonly (although I don’t watch live programs much, but instead watch the program recordings later).
It’s strange. I have not contacted support yet. Have you? Or do those of us who have TCL Roku TVs have to live with it :wink:? I have not waited long enough for the audio to stop. I have started it over from the beginning, or from the end and moved to where the video froze. What I have experienced is that when the video freezes, if you attempt to move forward or backward it jumps to the end when I touch either “arrow”. I know I have said this, but I have begun to pay attention to where the recording is (minutes) so I can easily get back close to where it froze.
I have 1 Roku TCL tv and DONT have this issue. I also have 4 Phillips Roku Tvs without this issue too.
I know what you mean. When it freezes, and you try to move forward or backward the status bar is moved to the end. You then have to rewind to the point where the freeze occurred, to which you have to guess. This is especially annoying when watching a football game and you have to rewind without noticing the score, so you don’t know how the game turns out before you watch the action.
Maybe this should be on the Roku or TCL support forum, if they exist (I’ve viewed the Roku forum but not actively).
Is this confirmed? I’l gladly get a Roku streaming stick for my Roku TV just to run TabloTV if this is a confirmed fix.
Well, all I know is that with the two, rather old, streaming stick+ models mentioned above, and running Roku OS software version 14.0.4, Tablo App version 0.8.801, and Tablo firmware version 2.2.52, this problem no longer occurs for me.
I have the same issue. Although I have a RCA Roku tv. I had hoped that this issue wouldn’t take long to fix but has been happening since a few updates ago.
If you haven’t already, these steps may help:
If you have an external drive connected, it may be viable to disconnect and reconnect it. Failing that, try clearing the Roku’s cache.
Beyond such, reach out to our technical support team: https://support.tablotv.com/hc/en-us/#contact , they should be able to assist.
If you have contacted our technical support team, feel free to DM us the email address you used to contact us or your ticket number and we’ll take a look.
this is crazy, this is exactly what i am seeing also, i did not realize it mainly happens with TCL roku TVs. I just created a post about it also, before i found yours
and mine happens with recordings, so should not be any antenna issues
I also have a TCL Roku TV, TCL 43S405. I had the exact same thing happen to me a few minutes ago watching my scheduled recording on Tablo 4th Gen of Game Six of the World Series. The game (and scheduled recording) had not completed, but almost. I was about 1 hour from the end of the recording. Video froze but audio continued. Pressed a button on remote, Rewind and it just went right to LIVE, i.e. at the end of the recording. At that point I could not rewind. From what I saw I knew that the Dodgers had won the game, so there was no point in doing a Resume. I just today installed a 3TB external HD for storage, had been using internal storage since I received the Tablo almost 4 months ago.
Weird thing is when Tablo formatted the HD (which had light use before as backup), it reported Unknown Error. But the HD was seen as there in the android Tablo app, 3TB capacity and 0 bytes used, so seemed OK and the recording was made. Everything wen fine until this snafu. Now, I do remember apparently the same thing happening another time with a scheduled Tablo recording some time ago, therefore before I brought the external HD into the equation.
If it happens again I hope to note where I am in the recording and start watching (“Rewatch”) and FF to approximately where I was rather than press Rew/Pause/FF.
This being virtually a year from the OP I have to think that Tablo/TCL/Roku have not resolved the problem.
I installed the external HD today in hopes of stopping the choppy playback I was getting using internal storage. AI was telling me that using internal storage was apt to cause excessive compression. So far, the video using external storage looks good. But tonight’s failure is vexing to say the least.
