When watching Live TV the video is a few seconds behind the audio. I have noticed others have this same problem. Is there a fix for it?
hellbound which device? I had the problem on the web app using Chrome. Some had success using beta.tablotv.com instead of my.tablotv.com. I had mixed results on both.
Same issue here, using Table 2 tuner to router to Nexus Player, all wireless.
Any suggestions?
Very rarely this happens to me (usually with live sports it seems). When I back out then resume playback it’s fine. Takes less than 2 seconds.
Same experience here.
This is something we are working on.
@getcashmoney’s workaround is a good solution in the interim.
Is this audio sync problem have been solved ? It’s important for me to know it before buying a Tablo pvr.
I don’t have any audio sync problems, mate. I mostly use the Roku but also the iPad and the Chrome programme on occasion.
