I’m curious if anyone is using multiple Tablo units to separate recording audio transcoding?
Since 5.11 was enabled, I’ve ultimately had to turn it off because a couple of my playback devices don’t support it (web app primarily).
I’ve considered picking up a second unit for stereo playback, but that just seems onerous. The idea of setting up copies of the recording sessions on both units, etc.
I also wonder - and I’m over-simplifying for sure - what if Tablo contained an option to use a virtual routing protocol and/or load balancing to enable a single ‘virtual’ tablo appliance on the network, supported by two or more actual appliances on the back-end that keep a single user-facing interface, but serve up the most appropriate content based upon the capabilities of the client?
At the end of the day, I suppose I should just upgrade my hardware so that they all support 5.11 - and stop dreaming about a hardware/software provider solving that problem.
