Using both a 4th Generation and Legacy on the same network
I transitioned my old legacy Tablo with the new firmware and can access it with the old Tablo app. However, I have a TABLO 4th generation (up to date) on the same network accessing it with the Tablo TV app. How can I access the legacy Tablo with the existing Tablo TV app?
If I recall, the scenario is in “the published migration” steps. So, you may want to revisit the steps. One of those “if you have a 4th gen, then… …otherwise skip” sorts of things.
Follow the instructions for users with existing 4th Gen devices here: https://support.tablotv.com/hc/en-us/articles/41395108651540-How-to-Enable-the-Legacy-Transition-on-Your-Tablo-Device
Once your legacy Tablo has gone through the transition steps, you can switch between devices using the Switch Tablo Device button in SETTINGS.
I finally had a chance to follow the referenced article steps and succeeded. Until I read the instructions, I did not know I needed to download the Tablo TV app on my phone.
Thanks for your help.
Happy to help @Bobnm!
