I can’t connect with android devices and Tablo. I get these messages:
dns_probe_finished_bad_config
Roku and PC’s still work. My router is a D-Link DIR-X3260. It’s been 2 days now. I’m not sure how to resolve it. any ideas?
Not sure what you’ve tried already, but here are some ideas,
Thanks. I’ve gone back to factory settings and restarted everything. I can still use windows and my Roku.
I tested my android devices at the Library. They work there, so it’s probably the router. D-Link wasn’t much help. I’m thinking of trying another brand of router.
Usually a router will have an option in the settings to reset to factory, but may also have a hardware button or pushpin switch on the back. Maybe a hardware reset would help.
…Or as you say, just buy a different router - who doesn’t like getting new toys? ha
Well I restarted everything, including unplugging the power supply, and reset the router. It’s alive! Thanks for your suggestions.
